Posted by Janicholson on May 31, 2008 at 09:52:29 from (66.173.50.157):
In Reply to: water in oil -- 400 posted by Hoss357 on May 31, 2008 at 06:03:37:
Pulling the oil pan is the first best test. If you look up in there with good light you will see at least where it it may be coming from. Look at the bottoms of each cylinder sleeve. Look where the oil drains back into the pan from the head. Putting a pressure tester on the radiator will assist (7.5 psi max) If it seems to be on a sleeve, trying a good (Barrs Leak) or other brand, might be a temporary fix if you need the tractor. Subaru and others use a sealant as standard coolant mix. It does work. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
