Re: Timing the magneto
Posted by El Toro on June 01, 2008 at 18:40:33 from (64.12.116.73):
In Reply to: Re: Timing the magneto posted by Dr. Bert on June 01, 2008 at 17:30:00:
To find out how much you're off is to bring No1 piston to TDC on the compression stroke again. Your timing mark on the damper pulley should be aligned with pointer, then remove the mag's cap and then see where the rotor is pointing. It should be pointing to the No1 plug tower. If its off you will need to pull the mag and place the rotor at the No1 plug tower. Then see if it runs ok. Hal
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
