Posted by mkirsch on June 04, 2008 at 16:34:37 from (64.80.110.50):
In Reply to: IH #8 Plow frogs posted by MAGMAN on June 04, 2008 at 12:10:47:
MAGMAN said: (quoted from post at 12:10:47 06/04/08) I have a brand new set of moldboards and points , I know there IH but they dont match my plows But I do have 3 or 4 sets of IH plows here, In Central NY.
MagMan
Hey Magman, you don't have any spare coulters around do you? Need 1-2 for my #60 plow so I can turn up some sod. Figure at least one for the rear bottom so it leaves a nice furrow for the next pass... Pullin three 14's with a 5220 Maxxum so power and traction aren't an issue.
Tom, here's a quick primer on plow parts, assuming a conventional plow. All directions are looking at the plow from behind:
1. Beam - The heavy cast piece that connects the bottom to the frame.
2. Bottom - The sum of the beam, frog, landside, moldboard, shin, share, and point.
3. Frog - The underlying frame for the plow bottom. All other parts bolt to it.
4. Landside - A wear plate that rubs against the side of the newly-dug furrow to keep the plow moving straight.
5. Moldboard - The large piece that turns the soil over and drops it in the open furrow to the right.
6. Shin - The leftmost piece of the moldboard. Early plows had a one-piece moldboard, but the Plow Chief and later Super Chief designs broke it down into a moldboard and a shin because the shin wears out at about the same time as the point/share, but the rest of the moldboard wears much more slowly. You can go through several shins before wearing out a moldboard.
7. Share - The lowest part of the plow bottom that digs the soil free across the width of the furrow.
8. Point - The very leftmost tip of the share. The point pulls the plow bottom into the ground. On the Plow Chief design, the point is a separate piece. Most bottoms have a one-piece point and share design because both wear out at roughly the same time anyway.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
