Posted by Hugh MacKay on June 07, 2008 at 08:52:39 from (209.226.247.87):
In Reply to: drawbars for 450's posted by NEKS on June 06, 2008 at 20:41:51:
NEKS: Whether it will fit or not, I doubt if it slows down wear on the hitch. Sidedraft, starting and stopping wears the pin holes on the hitch. this wasn't too bad on small tractors, but 400, 450 and 560 were terrible, especially if one was doing a lot of drawbar work. I always figured the surge of plunger on a baler did more dammage than most implements.
My 560 did mainly baler, haybine, forage harvester, cultivator and disk, all trailer machines. By the time it was 3 years old the hitch was so loose, it was like pulling the baler on a 2' chain. I rebuilt the pins and holes, but they didn't last anytime. Finally I went to H-M type drawbar.
If I were you and wanted to keep the hitch, I'd try and devise a drawbar between hitch links much like a 656 or 706. It's been awhile, so I'm not sure how difficult that fabrication might be. Park yourself behind the tractor and study the possibilities, keeping in mind hitch movement. I know you can save the cylinder and rockshaft, build the drawbar, then put a 3 point hitch on the side of the drawbar. I've seen that one done, and it worked well. He bolted the drawbar to same boses as rockshaft, also extended it to the belly where M type swinging drawbar fastenes.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
