Posted by mkirsch on June 07, 2008 at 18:37:05 from (67.240.251.254):
In Reply to: WD-9 problems posted by 71ford100 on June 07, 2008 at 15:36:36:
The magneto generates its own electricity, unless it's been cobbled up with an battery-type ignition coil. Only you will be able to look and see if that's been done.
Either way, it sounds like the magneto needs some work. It could be as simple as a tune-up (coil, condensor, points, cap), or you may need to have the magneto rebuilt. It should make a snapping noise every time a cylinder comes up on compression as you try to start it.
Since you suspect crud in the fuel tank, have you considered cleaning the fuel tank?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
