The bottom screw is where to enrich the fuel mixture for power. You probably have fuel blockage somewhere. Pull the gas line at the carb. and see if there's a full flow of gas. Catch the gas in a clean container. If the flow is good pull that tube fitting and check that screen that's been suggested. If it is clean you probably need to clean the carburetor thoroughly.
The coil can cause the engine to quit that's been suggested, but you need to check for fire to the plugs asap before the coil cools. Hal
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
