Posted by Bob M on June 08, 2008 at 09:06:04 from (74.74.140.11):
In Reply to: H won't shift posted by fredmich on June 08, 2008 at 08:07:26:
Fred - That happens a lot to these tractors when the end of the gear lever becomes badly worn.
If you know which two gears it's caught in, sometimes you can "worry" each gear back into neutral by working the lever by feel.
More likely however you'll need to remove the shift lever then manually move the shifter rails back to neutral:
- First block the wheels so the tractor cannot roll.
- Now knock out the gear lever pivot pin. It's secured by a small cup-type plugs at both ends. Take a punch and drive either cup in to push the opposite cup out, then pull the pin.
- Pull the gear lever out.
- Using a suitable bar (a large screwdriver works well) align all (3) shift rails to the neutral position (notches all in line and centered in the opening).
- Finally replace the gear lever and pivot pin. You should be good to go.
To prevent it happening again you'll need to build up the worn end of the shift lever. (Build up slightly with weld then grind the weld more or less smooth - a bit of a trial and error process.)
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
