Re: Delco alternator charging then not?
Posted by Janicholson on June 09, 2008 at 18:57:14 from (66.173.50.61):
In Reply to: Delco alternator charging then not? posted by Andrew Z on June 09, 2008 at 17:17:38:
If the ground was bad it would not charge when it finally does. The regulator is probably bad. Why not swap the regulator for a three wire setup and rock on. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
