Kidd, If I understand your post, youre still using the 6 volt genny correct?? I have used 6 volt gennys to charge at 12 volts simply by using a 12 volt Voltge Regulator and she worked NOTE Im NOT saying thats engineering correct or charged at any super high rate, ONLY that it worked although you could overheat the gennys field windings.
Next, you should have POLARIZED the Genny before you started the tractor if you changed battery polarity cuz you could damage the Voltage Regulator.
You need to decide what Polarity youre going to use,,,,,,,,,,,POLARIZE the genny (before starting),,,,,,,If you stay at the original polarity the ammeter should register correct buttttttttttt if you have switched polarity then you gotta swap ammeter leads as Bob suggested so it wont read bass ackwards.
If its a coil ignition the coil needs reversed if you change polarity. If at Pos ground the coils lil - gets ignition switch fed voltage while its other lil + wires to distributor but reverse that if at Neg ground.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
