John, the breather tube was designed to be an air inlet. The filter mentioned below is to keep dust out of the engine. If oil drips while the engine is running you may have a blocked tube in the engine ventilation system or the baffle missing in the valve lifter cover. The path through the engine is as follows: Air from the breather tube crosses the crankcase into the governor housing. It then flows through the small tube from the governor to the front of the head where it travels through a tube over the rocker arm assembly. This tube has a small hole punched in it to remove any blow-by that gets past the valve guides. The air/oil vapor then exits the back of the head and is taken directly into the air cleaner. The brass fitting that is threaded into the back of the head has a small orifice in it that can be blocked by deposits or oil sludge over the years. Also, a previous owner may have discarded the tube leading to the air cleaner altogether - which was the case with my "51H.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
