Is a Tee is the proper connection to make here? This is an open center system.
If you simply tee off the high pressure line, you create two paths for the oil to get back to the reservoir, and the oil will always take the path of least resistance. Pull the lever on the loader back, and the oil will just flow through the stock valve stack, and back into the reservoir without raising the loader. To get the loader to work, you will need to hold back one of the stock valves to block the second path while operating the loader, and release it when you release the loader valve to prevent the pump from overheating as it squirts the oil through the relief valve.
My understanding is, you want to connect the loader valve stack IN-LINE with the high pressure line. Pump to IN, Power Beyond to the tractor's stock valve stack, and OUT to the fill port on the reservoir.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
