I had the same issue with my 100 not too long ago. Are you running a distributor and coil? If so go out and buy another coil and swap it in for your existing one. You can test your coil till your blue in the face and even a bad coil will sometimes test OK when it's not. It is the center set of windings that will fracture and cause a short.
Go to AutoZone or a similar place and buy a new coil. They are under $20 and you can always return it after you try it if it doesn't solve the problem so you will have lost nothing.
Mine would fire for about a minute then die, let it cool down then it would fire again but then quit. I was getting gas, air, and juice to the distributor and plugs but just not enough. Once the coil got some juice running through it, it would heat and the fracture in the winding would expand and create a short or low voltage. This is an easy fix, report back to us with your results.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
