Re: 400 Axle housing
Posted by Owen Aaland on June 14, 2008 at 12:25:43 from (65.174.247.105):
In Reply to: 400 Axle housing posted by Ron Muhlenkamp on June 14, 2008 at 05:43:42:
Ron Muhlenkamp said: (quoted from post at 05:43:42 06/14/08) Thanks
Can the housing be removed without pulling the axle
Ron
No. The inner bearing is retained into the housing with four bolts. You would have to get those bolts out but they are behind the bull gear. You would need to get the bull gear off the axle to gain access to them. Once you have the bull gear off the axle will already be most of the way off the bearing.
With the outer bearing cap off, remove the PTO. Remove the bolt that holds the bull gear on the axle. Remove the washer and reinstall the bolt. Put a spacer between the axle bolts and back the bolt back out again. As you back out the bolt it will push the axle out of the bull gear and bearing.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
