Posted by Allan In NE on June 16, 2008 at 15:41:16 from (148.78.243.26):
Got a problem; not great, but it is just driving me crazy 'cause it just isn't "right".
A little slop between the pitman arm and it's gearbox shaft. Would probably outlast me the way it is, but it just bothers me.
The shaft is roughly 1 1/8" in diameter, splined and TAPERED. Splines are not quite as big as a 540 PTO shaft and roughly 1 1/4" to 1 1/2" long.
Anyhoo, over the years, this thing has been allowed to get loose and wobble the cinch fit out a bit. Not "real" bad, but enough that I just don't wanna trust it.
I can't just "washer it up" on the taper, because then the pitman arm would be too close to the gearbox and would hit the cover bolts.
How in the heck can I tighten that taper-fit up? Maybe "shim" it with a wrap of tin foil in and around the shaft splines?
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
