460 Utility tel a depth
Posted by Gary in Mozarks on June 18, 2008 at 15:41:53 from (66.43.47.111):
I finally found a section on the teladepth in the 460 IT manual and it says the unit should go "off pressure at each end of the 90 degree lever range. Mine isn;t going off pressure. I removed the guard so I could move the lever more than 90 degrees and I have pressure through about 140 degrees of movement of the range lever. Anyone have experience with these things? Also the rock shaft lifts if I move the range lever forward and down. Is that correct or do I have the hoses reversed? Thanks in advance
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
