John Cambern said: (quoted from post at 09:16:30 06/21/08) I just got this tractor and wanted to know the specs for changing all of the oils. The transmission oil looks like a 30weight with no additives. The motor oil I can see and tell what needs to be in it( SAE30). I am unsure of the transmission oil and how much it holds. Is this the only two locations for oil.
Are there any other suggestions for what I may need to do before using the Model M on the ranch. I plan to work it mowing and digging post holes ect.
Thanks
The trans/diff takes 13 gallons of 90 weight gear lube. The belt pulley takes lube. The steering box takes lube. All kinds of places on the tractor need lubrication if you want to take care of it.
Yes, here is another suggestion: Buy a Farmall M Operator's Manual. It has an entire section on oil and lubrication , including frequency, which will be of great help in caring for the tractor and keeping it from wearing prematurely. It will also teach you a lot about your tractor.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
