Posted by ScottyHOMEy on June 22, 2008 at 06:55:04 from (71.241.211.194):
In Reply to: A clutch posted by HENRY E NC on June 22, 2008 at 06:01:35:
Check and adjust the free-play on your pedal first. If the bearing is bad, it will be noisy when it engages. Generally harmless in the immediate term, but it wears harder on the clutch fingers.
Also, there's nothing real unusual about what I call the "Farmall Grind." On unsynchronzied trannies like yours, it is considered normal to have to hold the clutch pedal down for a second or two (or three) to give the shaft time to quit spinning and be able to get it into gear without making any noise. And that'sjust to strt from a stop. If you're gettin' ideas bout bein' ble to shift on the fly from one gear to another with no grinding you're gin' to ne to grow one more arm. This arm should be on your left side so that you can operate the shifter while adjusting the throttle in the appropriate direction for the shift up for downshifts, down for shifting up, and you can still expect some grinding and kerchunking until you get good at it. Having two arms on the left will leave your right arm free to pay attention to the direction of travel and adjust as necessary.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
