The radiator should sit more or less vertical. However if it leans forward or back bit it won’t hurt anything so long as the fan blades clear the radiator core.
Suggest mounting the grille to the rad, setting the the hood in place, then adjusting the stay rod as required to get the best fit between the grille, hood and gas tank.
When the tractor was built heavy gear oil was installed in the steering gear box. However gear oil will leak out thru the pivot shaft seal as the seal ages and the pivot shaft wears. Many of us have had excellent luck packing the gearbox with a good quality wheel bearing or corn head grease. It’ll lube the worm and gear just fine and it won’t leak out even if the seal is bad.
Can’t answer your question about Behlen PS (I’m a Charlyn PS guy myself!)
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
