Hi, could be a sticky valve in the MCV valve. The standard hydraulic pump is about 12 gpm. The MCV splits the 12 gpm into 3 gpm for PS, PB and oil cooler, the remaining 9 gpm go to 3pt & remotes. If the splitter valve sticks open then all 12 gpm go through the PS, PB and oil cooler circuit. Make sure that you have plenty of hydraulic fluid in the transmission, can over fill by 5 gals.
Next time the problem occurs turn the steering wheel one way or the other to the max until you hear the hydraulic relief valve buzz. Sometimes this will dislodge dirt or stuck MCV valves.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
