Re: Hey Brownie ; Farmall A Dead
Posted by El Toro on June 26, 2008 at 05:04:35 from (64.12.116.73):
In Reply to: Hey Brownie ; Farmall A Dead posted by plh_in on June 25, 2008 at 18:13:01:
third party image
You need to check for voltage on the small terminal when your key is twisted to start or you push a starter button. You may not have voltage at the key or none at the starter button. You may need to trace the feed wire to see if its broken or not making good contact. If your solenoid has 2 small terminals one may be the feed terminal to your switch. The terminal that cranks the engine usually has an S and is only hot ( has voltage) when cranking the engine. Hal
PS: I had to replace the solenoid on my tractor it just kept cranking. Cost about $5.00.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
