> I think the correct bolts have holes that let > oil go from yhe gallery to the rocker stand.
None of the bolts are drilled (and it was oiling ok last year when I adjusted the rockers). I have the rocker assembly apart and can see the oil holes in the 1st and 3rd rocker stands and the shaft: it's clear that the oil is to come up in the clearance around the bolts (or if it isn't I don't see how it could work).
> Your owners manual will have a lubrication > diagram.
The engine shop manual has a diagram showing that the cam bearings distribute oil to the rockers and the governor but does not detail the route to the rockers.
> I thought it was the middle stand.
The first and the middle stand are drilled with oil ports opening to the shaft. The shaft has a matching hole for the port in the first stand but not for the middle one. Possibly the middle stand does not actually carry any oil despite being drilled.
Perhaps the camshaft bearing is so worn that the oil all leaks out without developing enough pressure at that point to reach the rockers. But if that is true why didn't the oil I poured into the holes drain away quickly?
Perhaps the camshaft oil gallery is clogged. But if so, why do I see lots of oil on the cam followers?
I'm reluctant to spend $275 and a lot of labor on a reman cam until I know what is going on. I'd hate to put that cam in and then need an engine anyway.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
