Posted by LeonOk on June 27, 2008 at 07:27:58 from (199.83.40.36):
How tight should and motor be after a rebuild. I am in the process of rebuilding an F-20 with new rings and resurfaced rod bearings. The rod bearings all have 3 thousands clearance. The motor will turn fairly easily with a pry bar until I tighten the last rod bearing—it doesn’t matter which one is last. After tightening the last rod bearing the motor tightens up quite a bit. I can still rotate the crank one full revolution but it takes a lot more effort. Is this normal or too tight? Thanks
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
