Easy to do if you have a complete gas engine. Hood sides are different but can be used, Gas air cleaner, hydraulic pump,lines, coolant pipe,and throttle notches needed. Also gas linkage rod from governor to throttle linkage lever near bottom of air cleaner. Also the lever has a little bigger hole than gas ones in it. Hand starting ratchet in bolster is different, if it matters. Fuel tank can be used by pluging one outlet hole. If you change to a big tank the hydraulic lines under tank need changed also.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
