That is as easy of fix that you will ever do , First remove the steering wheel with a steering wheel puller and two 1/4 inch fine thread bolts that are at least 4 1/2 inchs long as it makes it easier with the long bolts . Clean out the holes in the wheel and chase with a 1/4 fine tap . Remove the nut that holds the wheel on install the puller and tighten it up and give it a rap with a hammer and it will pop off . Next remove the snap ring that holds the seal in then set the steering wheel back on the shaft and give a quick hard turn don't care what way you turn it and the seal will pop wright out clean up and install new seal replace snapring and put the steering wheel back on and go to work .
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
