Posted by Bob Kerr on July 05, 2008 at 14:32:38 from (64.12.116.73):
In Reply to: 10-20 runs again posted by JDMAN60 on July 04, 2008 at 16:24:54:
Glad you gotther going! It was a great day when mine fired up after sitting 30-40 years. I am guessing you pull start it? If not be carefull if you are not sure where the spark is retarded and use the crank handle it may flip backwards. If I remember right look at the alum cap on the mag and when the rod hole is down all the way it is "off", to start it just has to be up a 1/4 inch from all the way down with the E4A mag. Don"t forget to flip the impulse lever on the mag or it will not have enough speed to make spark. If it has an F4 Mag it has automatic impulse coupler and will make a click sound when it sparks but it will still have to be retarded the same as the E4A to crank it by hand. If you have the choke on to run, it is either not getting enough fuel or too much air to run. Look for clogs in fuel line and carb or a loose or leaky manifold.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
