Re: anyone have a #
Posted by Daniel H. on July 06, 2008 at 11:19:40 from (66.226.34.159):
In Reply to: anyone have a # posted by tn terry t on July 05, 2008 at 19:38:18:
I believe the seal from Case/IH can be ordered with the wear sleeve. If you already have a seal, NAPA should be able to order a speedi-sleeve to fit the pulley. You have to measure the pulley:
[quote:0c41f62fe0]Correct size selection requires that three measurements be taken and averaged. Measure the shaft diameter just ahead of the wear path (not in the track worn by the seal) at three positions: 12 – 6 o’clock, 2 – 8 o’clock and 2 – 10 o’clock. The average of these readings will compensate for an out of round shaft. Compare your average diameter with the size ranges in the Speedi-Sleeve Selection Charts, and choose the appropriate sleeve.[/quote:0c41f62fe0]
Here is the link to the sleeve sizes:
http://www2.vsm.skf.com/Files/Brochures_in_PDF/Speedi%20Sleeve.pdf
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
