The word that needs doing is "polarize". It's done by using a short piece of wire and touching the bare ends from the voltage regulator BAT terminal to the A terminal, Just touch it momentarily, there should be a small spark. Don't hold the wire there after you see the spark. If it doesn't charge after that, try grounding the FLD terminal to the generator case. It should show charge if the generator is good. That would indicate that your voltage regulator is probably bad or as you mentioned your ammeter could be bad. Probably the very first thing to do is to clean ALL your connections, then do the other suggestions.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
