Posted by MN Dave2 on July 09, 2008 at 19:59:33 from (204.221.132.81):
I have a carb on a Super H that is enough to make a preacher cuss. Tractor will appear to be cured, sometimes will work for 30 minutes and the next time will flood right away.
I've already blown out/cleaned carb, replaced the float (old float sure looked ok, but I'm past flustrated), replaced the needle and fitting (twice) that float opens and closes to allow gas into carb. Float is not touching/hanging up on inside of carb. Float needle seems to hang up sometimes, but is loose in new (and also old) fitting. Both the little hard rubber tip on needle and the brass fitting that it fits into look perfect. Last time we worked on it, tractor started up fine, flooded so that it would only run with choke 2/3 closed (warmed up tractor... totally no need for choke) tractor ran poorly until I turned off gas under gas tank, then ran fine until it ran out of gas. Gas is tank is not under pressure... Thanks for the help!!!!!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
