Re: IH 140 Governor ?
Posted by Hugh MacKay on July 10, 2008 at 01:27:08 from (216.208.58.109):
In Reply to: IH 140 Governor ? posted by AJ 140 on July 09, 2008 at 06:16:19:
AJ: You say stick, stick where, low idle, high idle or somewhere in between? Give a bit clearer description of exactly what it"s doing.
The governor is designed to control low and high idle rpm as well as making it steady at the position you set throttle.
I doubt if your problem is adjustment, governor probably needs some rebuilding, unless someone has been playing with adjustments.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
