I found a 3/4" socket that came close but it was a bit loose and the length was awkward so I used the plywood plug I had already made. 3/4" flat washers also come close.
Anyway, I got it in. I ended up mostly driving it because tightening the bolt tends to rotate the bearing, misaligning the oil holes. If I ever do this again I can see how to avoid that problem. The bolt should go in from the back and the nut should be tightened while the wooden block is held still.
I used a 3/4" floor flange against the wooden block on the front (I think I could have dispensed with the block) but I had to use a piece of 1.25" channel on the back due to lack of space.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
