Posted by charles todd on July 14, 2008 at 21:06:57 from (205.242.95.138):
I have lost all hydraulic pressure to my remotes but still have power-steering and 3 point lift functions. Since I have these two functions, both pumps must be working. I was not operating the tractor but the operator said he actuated a remote valve and heard a "pop" then the remotes quit.
I looked at the tractor and pulled the check balls from the remotes and they appeared to be fine. The only two points I know to look at are the relief valve under the seat and the power-steering flow divider on the LH steering column.
In the morning (July 15)I am going to try to get the hydraulics to atleast get the loader off the ground so I can get it on the trailer. I am also going to change the hydraulic pump in the field since I have a new one if I fail to find a failure in the flow divider or relief valve.
Any help from the GURUS would be appriciated.
PS: I will take my laptop and cellular modem in case someone post the fix or I need help.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
