Posted by John T on July 15, 2008 at 06:16:23 from (66.244.97.31):
In Reply to: Ammeter posted by GordoSD on July 15, 2008 at 05:38:13:
You can just use some jumper wires,,,,,,,,,the ammeter in question,,,,,,,,,,a battery,,,,,,,a load such as a head or tail light etc. to run a "bench test" as you asked...
The SERIES circuit could run typically from the battery Pos post,,,,,,,to and through the ammeter in series,,,,,,,,to and through a headlight etc.,,,,,,,,,return to the batterys other Neg post. The needle should deflect typically say 3 to 5 or more amps (depends on load ohms) and then if you reverse the ammeter leads it should deflect thE opposite direction....
With just an ammeter and an ohm meter,it should read very low ohms continuity through the ammeter but if its open its baddddddddd. It can still be continuous, however, but still a bad ammeter mechanically speaking due to a rusted/stuck/corroded needle assembly
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
