Re: Excessive blowby in D560 farmall
Posted by ih560 on July 17, 2008 at 17:43:00 from (204.118.68.33):
In Reply to: Excessive blowby in D560 farmall posted by arkie on July 17, 2008 at 15:56:02:
arkie said: (quoted from post at 15:56:02 07/17/08) I have a 560 Farmall with d282 that has very little power and alot of blowby.I was told to pull the oilpan and see if it sucked a sleeve.I did that and it all looks ok.I need to know if this is a valve job or a resleeve and rering job.Can I pull the crank and cam from below?Any help would be greatly appreciated as I really like this old gal,and I can"t bring myself to send it to China in pieces.Thanks for your time!
As far as your question about removing the crank and cam, you can remove the crank once you remove the engine from the tractor, until then there are a few things in your way. You can remove the cam from the front of the engine by taking the front engine cover off, then you will have access to the cam. Of course there are many more things involved in the process but, to answer your question, no the crank and cam cannot just be removed from the bottom of the engine.
Blowby is fairly common for a lot of old diesel engines, can you give us some more details about the engine, is it smoking from the exhaust and what color (warm, cold, under a load?)? Does it start easy or hard, How many hours are on the engine?
There are a lot of possible reasons why it has no power, it could be your injection pump, fuel filters, valves poorly adjusted or just a plain worn out engine.
Give us some more details and I am sure someone can help you out.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
