756 Engine Swap
Posted by MN Scott on July 18, 2008 at 16:30:39 from (206.9.216.51):
I have a 756 with the 310 German diesel. Its seeping coolant in the oil from the sleeve seals I think. Its also getting alot harder than it should be to start with oil pressure on the low side. I found a 715 combine 310 engine with low hours for about what a piston and sleeve set would cost for my 310. A total overhaul for my 310 with parts and machineing done right by myself could easily run $6000 to $8000. I have been searching the YT archives and the general leaning of the postings is everything will swap and bolt in except the flywheel. CB ONT installed a D310 combine engine in a 756 gas but did not state what he did to make a flywheel work. Has anyone done this swap and knows what it would take to make it work? Remachine the 756 flywheel or remachine the combine flywheel? Adapter hub? I have not seen the combine engine so I don't know what the crank hub looks like.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
