It could be rust or dirt that's not allowing the snapping action on the impulse when cranking. It could be the the spring is broken or where the fingers contact the posts are worn not allowing the impulse coupling to "windup" to get the snapping action with the hot spark when cranking.
If you ever decide to pull the mag you need to pull the cap and see where your rotor is pointing and make a sketch. Once you pull the mag don't ROTATE the engine. When the mag is repaired you rotate the rotor shown in your sketch and install the mag and your engine should start. The same applies to a distributor.
You should contact 'Jon the Magman' at www.farmallall.com and ask him his opinion since he rebuilds these mags. Hal
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
