Thanks to each of you. I was going to borrow a pressure pump and test the pressure myself. Now I will not. The fellow at the radiator shop estimated as much as $300 to remove and clean the radiator and re-core it. I can buy a new one for just over half that. I think I will just remove it and rod it myself. Worst case is I need to buy a new one. I am wondering whether there is a leak because I do not see fluid when I look in the top of the radiator. It is probably worth filling it with half water and half antifreeze to see what happens - or... just put water in it and drain it after a while if there are no obvious leaks. Any thoughts on this plan??
Today's Featured Article - Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
