M Carb Dumb Question Time
Posted by Dan Bear Kelley on July 25, 2008 at 12:14:57 from (206.53.20.149):
OK. Dumb question time. Y'all helped me with adjusting the valves. I'm hoping you can help me again.
I've rebuilt 4bbl carbs before, and I ordered a carb rebuild kit from YT Mag's parts page. I don't foresee problems actually rebuilding the carb for my Farmall M. However, I do see issues with adjusting the carb and governor after reinstallation.
There's the idle adjust, the power adjust and the governor linkage. I assume I start with the idle. With a 4bbl, I adjust for highest vacuum. How do I properly set the idle on a Farmall M? Is there a port where I can tap off vacuum?
Then, I assume I adjust the governor, so that idle is the right RPM at the bottom notch on the throttle handle. Is that right? Or do I adjust the governor so that max RPM is at the highest notch on the throttle handle?
I assume I have to have a little back and forth to get both the idle and the governor set right.
Then, there is the power setting... I don't even know which screw is the power setting and which is the idle setting. And how do I set the power screw properly?
Yes, I do have an IT manual for the M, but this web site generally has practical ways to do things. You folk out there are GREAT! So, I rely on y'all more than the writings of one person.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
