If youre at 12 volts now you need to EITHER use a full true (some people call internally ballasted) 12 volt coil AND NO BALLAST or else a 6 volt coil with the external series voltage dropping (12 to 6) ballast resistor.
A 12 volt coil will have somewhere around 3 to 4 ohms primary resistance as measured between its lil + and - terminals while a 6 volt will be more like 1.25 to 2 ohms.
This ONLY affects the primary ignition circuit NOT the charging system
Once the ammeter is wired correct it would swing over to - discharge if its not running n you turn on lights and/or ignition then swing to + charge running if the charging system is okay. A battery polarity reversal requires an ammeter lead swap so it dont read bass ackwards.
For a troubleshootign procedure for non charging see my URL link in a post above
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
