Posted by Idaho Ron on July 26, 2008 at 10:03:06 from (208.98.173.2):
Well yesterday I was working on my Hydraulics on my Super C. I changed the oil seal on the top on the auxiliary control valve. Last time I messed up the seal, this time I got it right. I started to look over the hydraulic cylinder on the FH I had JUST rebuilt. I saw a leak! I thought it might be the hoses so I pulled them off and replaced them.
First thing that went bad. The small screws that hold the spool valve broke off. After that I got the hoses and put them on. I had the same leak. This time when I got to looking at it I found out I had over tightened the hose end and the head of the cylinder had a crack in it.
I took it apart and soldered it. I put it back on and it was still leaking. I took it back off and hit it again with solder. This time I it closer to the hole. I put a ¼ nipple in the hole while I was soldering it. I almost got it stuck but I did get it out. I got it on about 10:30 last night and tried it. Well I got the hoses backwards, but I think the leak is stopped. If it does it again I think I am going to put a short pipe nipple in it and solder it in.
Have any of you ever had that happen? How did you fix it and did it hold? Thanks Ron
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
