Posted by Jim Becker on July 28, 2008 at 08:25:31 from (71.123.128.52):
In Reply to: Farmall B-rims posted by Dave H (MI) on July 27, 2008 at 14:07:10:
Gene hit a lot of good points. One of the reasons for the different styles of loops is that they had to be different for each width of rim. Needed to be to maintain the correct offset. I suspect that IH bought a lot of tires already mounted on the rims. So most or all tire supplier were rim suppliers, and THEY may hae been buying rims from whoever too. I know I have seen rims with Firestone's name stamped in.
One more tip on measuring. Don't measure the rim you are replacing, measure the one on the other side. After years of swapping tires around, some tractors end up with mismatched rims. If that happened to your tractor, you want to match the one you are keeping, not the one you are replacing.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
