Posted by Paul in MN on July 31, 2008 at 10:37:27 from (71.210.156.138):
In Reply to: 345 to D414 swap posted by FarmerCMS on July 30, 2008 at 18:55:40:
The head mechanic at our now closed IH dealer did a similar switch on a Loadstar maybe 20 years ago. My memory is pretty sketchy, but here is what I recall. The engine compartment in the Loadstar is pretty short, having been made for the 304/345 V8. The distance from the radiator to firewall is less than needed for the longer 6 cylinder diesel engine. I think he moved the radiator forward and modified the grill to accomodate. The longer block and oil pan fit between the frame rails and cross pieces, but he gained the extra length for the now more foreward fan to clear the radiator. I can't recall the reason, but he had to lean the diesel over about 20 degrees to clear steering or suspension members. Then custom built motor mounts. With the engine leaned over, but the tranny needing to be upright, he may have fabricated an adapter plate at the bellhousing. Then the rear axle gearing is wrong for the diesel. The diesel likes to put out its power in the 1900-2300 RPM range, while the V8 pulls hard up to about 3600 RPM.
Bottom line: he said that he'd never do that switch again, it was an interesting piece of work, but not a very good truck. I respect his efforts and craftsmanship.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
