Posted by SuperA-Tx on August 01, 2008 at 16:03:00 from (4.90.54.36):
I picked a good day to remove the resistor. 103 degrees outside in the shade so I figure in the metal building it was close to 112 and without a breeze or fan.
Everything went smoothly so after I got the old wire removed and the new one hooked up I figured I better check it out and see if the SA started. Pulled the ignition switch on and then pushed the starter button on the starter and it didnt make a sound. I figured I didnt have the wires on there good so I checked it again but they all checked out fine. I stood right there beside the battery box and pulled the ignition switch on and then pushed the starter button, again NOTHING, not a sound.
I thought for a second of what I did wrong then I looked at the battery box. I had to just bust out laughing because I had'nt replaced the battery. I may not have a degree like John T but even I know you have to have a battery in there. Started right up after that little error with the battery. LOL
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
