Posted by Ted in NE on August 02, 2008 at 18:09:57 from (74.85.105.182):
In Reply to: TD9 injectors posted by FordsonMajorPat on August 02, 2008 at 05:08:33:
Pat
The hole I was refering to is in the plate below the nozzle valve you cleaned. Can get some carbon build up over time. Clean with a tip cleaner of the right size. Valve adjustment is very important. Also check for stuck starting valves while you have the valve cover off.Push down on the cup that goes over the valve & spring retainer make sure they are coming all the way up. Can free them up if needed by removeing the rocker arm assembly & cup over the valve. Use penetrateing oil & work them up & down. If to sticky remove the spark plugs. You can spray the valve stem through the plug hole. Usually will free up just takes patience. Quick check for stuck starting valves, crank over with change over lever on diesel. Will crank faster on cyl with stuck starting valve.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
