Re: repair steering mechanism on 424 intl w/o power steering
Posted by Rex in Australia on August 03, 2008 at 03:56:27 from (61.69.245.175):
In Reply to: repair steering mechanism on 424 intl w/o power steering posted by Charles Arp on August 02, 2008 at 19:13:51:
You'll probably find like i did that the bearings have collapsed and the worm is lifting up and down when you turn the wheel. Plus the peg from the sector shaft will probably be very worn.
Bearings are available as single balls from the bearing suppliers, adjusted by shims if I remember correctly. I could not get a new peg so basically hollow ground it so that the damaged parts were clear of each other and it ran on the less damaged parts. Then adjust the box in the normal manner.
Caused in my case by water leaking in to the steering box and rusting out the bearings!
Good luck and God Bless,
Rex
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
