Re: 414 value question
Posted by JimB2 on August 03, 2008 at 17:25:09 from (99.241.179.24):
In Reply to: Re: 414 value question posted by poorfarmall1 on August 03, 2008 at 16:52:40:
Hi Poorfarmall, yes 3414 and 3444 were the industrial models, may have heady duty front axle, front mounted hydraulic pump and some additional hardware.
Re Brakes, now it has been 40 years but here is the fix, remove the disk brake housing by removing the adjustment bolt from the brake pedal lever and the 4 bolts that hold the housing to the side of the differential. Inside you will find 2 disks and an expansion mechanism that has 3 rollers in between held together with 3 springs.
The brakes work by the rollers running up the ramps in the expansion mechanism and pushing against the disk surface. First cleanup the rollers and ramps, do not apply any kind of grease that brake dust will stick to. Next examine the disks for wear, most likely they are just glazed and shiny. I would take a wire brush and buff them to remove the glaze. The other problem that happens is when the disks are replaced, the new disks will only make contact on the outer edge of the of the worn brake housing. Solution is to grind a 1/16" off all way around the outside of new disk so they will contact the worn surface of the housing. Someone must have invented a tool to turn the worn brake housing surfaces but I never had access to one.
Good Luck
JimB
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
