Re: engine for a Farmall B
Posted by ScottyHOMEy on August 06, 2008 at 06:59:13 from (70.105.231.176):
In Reply to: engine for a Farmall B posted by Frank C on August 05, 2008 at 18:51:29:
Should fit, but if you use a SuperC motor, save the cooling outlet that runs from the head to the radiator from your. The dimensions are different for the taller radiator of the SuperC. You might also have to find or fab up a cover to replace the hydraulic pump, unless you can rig up something so that you can make use of it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
