Posted by No tools on August 06, 2008 at 21:38:00 from (71.79.47.23):
In Reply to: Outer Bearings posted by HFarmall on August 06, 2008 at 19:16:01:
No you do not have to remove top cover.Drain part or all the oil. Remove PTO.That will access you to retaining bolt in end of axle.Remove bolt /Then 4 bolts on end of axle housing (out bearing/oil seal retainer) pull the whole axle out if you wish.Usually you don't have to.
Also get the inner same as above just lay/tilt bull gear over out of way.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
