On a negative ground system, the coil's (-) terminal goes to ground, as well, through the breaker points.
Your's is backwards, which makes for a slightly less effective spark at the spark plugs.
When the coil's polarity is correct, the leading edge of the spark at the plugs is negative-going. Since the center electrode is hotter than the ground electrode, this makes it easier for the spark to occur, due to the "Edison Effect". (Electrons are emitted better by a HOTTER object better than by a COLDER object.)
On modern vehicles with a "waste spark" system that fires 2 plugs at once, one fires with (-) polarity and the other of the pair fires with (+) polarity, yet the engine runs well 'cause the ignition system has a HOT enough spark to fire even the reversed-polarity plug efficiently.
On your old slow turning, low-compression tractor, the reversed-polarity coil will be a problem only if the spark is marginal to begin with.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
