Been following your saga for some time as I have a 504 which I recently put P/S on. Agree with Allan about placing power beyond valve between P/S flow divider and aux valves. You will indeed need a return to sump for the power beyond. Only place I know of that is big enough to dump that much oil is the filler plug without tapping another hole in the xmsn case. I don't think the 1/2 inch pipe plug that is the fluid level check/power steering/oil cooler return will be big enough to flow what you need. You have the 17GPM pump if I recall correctly.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
