Posted by RN on August 12, 2008 at 15:55:58 from (216.165.130.126):
In Reply to: E85 in M? posted by rbower on August 12, 2008 at 15:28:04:
Treat the E85 as dual fuel- start gasoline and switch when warm. IHC had some alky burners in 30s for a couple limited markets- Cuba was one using some ethanol, a couple industrial users around dock areas also used ethanol mixes for safety reasons, less explosive risk and fires could be doused with water. If you're in Minnesota where E85 is becoming more common- consider the highest compression pistons available. Extra fuel filter in line also helpfull, clean fuel tank good and watch carb for leakage, check oil. Gasket and seals in fuel system are main concern. RN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
